M
Mark777s
Hi i am currently installing a Vehicle ramp to my garage, i have discovered that the motor is a dual 3 phase motor and can run on 230 volts 3 phase i have rewired the motor to suit. I am using a Yaskawa Ac Drive V1000 inverter to take 240v single phase to 240v three phase, with the unit programmed i can operate the motor forward and reverse using the override button in control box on solenoids. The problem i have is when using the ramp switch up or down the solenoids are buzzing and not activating these switches,they vibrate when activated as if they are trying to pull in. can anyone help? many thanks.
the picture is of internals of control box on ramp, the two black solenoids are on the right with switches that buzz in the center of them
