Discuss carbon filter on cooker hood in the Electrical Appliances Forum area at ElectriciansForums.net
All cooker hoods are much the same.
the flat grease filter is in the metal grill.... which is just a plastic clip you slide back with a finger.
If the carbon filters are the round type, they should just unscrew from the fan housing.
According to one manual I looked at, you might need to unscrew in reverse.... ie, clockwise to loosen, not anti-clockwise.
Thanks... Done
Reply to carbon filter on cooker hood in the Electrical Appliances Forum area at ElectriciansForums.net
I'm looking for a recirculating cooker hood as I have a flat and the cooker isn't near the external wall. Most of the cookers have carbon...
Hi My Kitchen has never had a cooker hood installed. Where the new hood is going to be situated is some distance from any of the outlets in the...
Hi, can someone please advise on where if anywhere I may acquire an adapter to duct out this old Elica cooker hood. The hole is 150mm x 90mm and I...
  • Locked
Hi I also posted this on the DIY Electrical Advice - Electrical Appliances Forum My Kitchen has never had a cooker hood installed. Where the new...
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
