Discuss Case for long 600mm to 1000mm Drill Bits. in the Electrical Tools and Products area at ElectriciansForums.net
local carpet shop will give you the cardboard tube from a roll. it's about 4" diameter and free.
This is what I do, use each of the drill boxes to store the appropriately sized bits, then a piece of 50mm pipe with the screwed end pieces - you can usually get the pipe off site and the ends are pretty cheap from screwfix/toolstation
I tried the map/chart/art tube things and they fall apart very quickly.
I don't do much "work", so no van just a car so the same issue as you when I actually have to do something!
That’s a brilliant idea. I’ve ordered these:
Solvent Weld Access Plug
www.toolstation.com
Solvent Weld Waste Pipe 3m
This solvent-weld waste pipe channels water from your drainage system. It's suitable for carrying waste fluids too, and even industrial chemicals. The 3 m length gives you a good stretch of pipe that can be cut down easily. This piping is fitted by slotting over your existing pipe – the interior...www.toolstation.com
Use old bog rolls for general small drills?4” Cardboard Tubes.
Order pvc conduit or minitrunking from CEF and get it delivered to your house. It comes in 3m long cardboard tubes.
re: 1st.pic. where can i buy those anti-gravity drill bits?This is what I do, use each of the drill boxes to store the appropriately sized bits, then a piece of 50mm pipe with the screwed end pieces - you can usually get the pipe off site and the ends are pretty cheap from screwfix/toolstation
I reckon there's alot of velcro involved in that pic...re: 1st.pic. where can i buy those anti-gravity drill bits?
I have a 16mm and a 25mm one meter SDS bits on the van.I am looking to buy a case for storing my SDS Bits in . As currently I’m using my car for work and would like a way of transporting them whilst working on the job out of the engineers van.
I just threw the boxes and tubs in the air, and took the photo when they were in the correct formation.re: 1st.pic. where can i buy those anti-gravity drill bits?
Reply to Case for long 600mm to 1000mm Drill Bits. in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
