Discuss Cause of massive night time usage? in the UK Electrical Forum area at ElectriciansForums.net
Is 7kw/h overnight normal usage? I thought I read somewhere that 11kw/h per day was around what the average household uses. Maybe I’m way off.
No such thing as the "average" household... they are all different. Similarly, my water rates bill tells me that the "average" single occupancy house uses 181 litres per day !! Wow... how does anyone use that much ???
The cess pit we have at work, has two large pumps that alternate. They are designed to 'chew up' anything, but get jammed by what people flush down the toilets. Doesn't like dry wipes, underwear, plastic bottles etc. Perhaps your pump has come across these objects?
Hi All,
An update on the septic tank issue. Hopefully this will make sense.
As I understand it, the outlet pipe broke causing the pump to become permanently submerged and therefore pumping constantly. Hence, the huge (by my standards) electricity bills. It should only come on maybe twice a day for a short period, as per one of the replies above. Thankfully the pump itself isn't burned out and is still working fine. I think he said it's a 1 kw pump (does that sound right?).
Good that you have discovered that although doesn't explain night time usage as it would be pumping 24/7 in that situation.
The pump would be sized for the system but for a domestic 1kw doesn't sound like an overkill.
Reply to Cause of massive night time usage? in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone In September 2023 I rented a beautiful 3 bedroom apartment, with all electric supply, no gas powered appliances. I noted down the...
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
Hi everyone, I've been reading this forum and was hoping I might be able to get some advice! The RCD switch for my sockets has been tripping...
13K
