Discuss cavity walls in the Australia area at ElectriciansForums.net
O
ONIT
Evening,
DOSE ANY ONE KNOW OF A REG SAYING YOU CANT RUN T&E ON A DOMESTIC JOB WITHIN A CAVITY WALL ITS AN EXTURNAL WALL
ALL REPLYS WELCOME MANY THANKS
I think its one of those grey areas, best to be avoided if you can, but if i were doing it I would put the cables in a bit of flexible conduit for a bit of protection.
By the way an easy way of getting down a cavity is a 5.5 sds drill bit on the end of a bit of string
Evening,
How about...
1. Cables inadequately supported.
2. Cable current capacity reduced by 50% if the space is filled [now or later] with cavity wall insulation.
Regards. spaek1 :)
I came across this problem some years ago and discovered that it is against building regulations as it could compromise the function of the cavity.
I understand that rodents and water can access an external cavity!
I guess replacing a cable in a rotting rodent environment wouldn't be much fun.
nor some poor sole with burnt fingers from a switch wire carrying water ( condensation or leakage) from the cavity.
I guess these are all reasons why it cannot be done any more although you can replace a cable wired to a previous BS version following its original route????? If not qualified Crazy!!
Reply to cavity walls in the Australia area at ElectriciansForums.net
Hi all. Just a quick one if I may. I am currently about to fit 3 gang smart touch switch at my front door but owing to powering two sets of...
DIYer here. I'd like to install an electric car wall charger myself. It calls for 6/2 romex which I have. Unfortunately my panel is in my...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
Hi all, I'm planning to remove a stud wall seperating my dining room and kitchen. On the dining room side of the stud wall, there is a double...
