Discuss CCTV cable drop in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Flash
Can any one point me in the right direction, I've been asked to quote for power supply only for 5-6 cctv cameras the distance of the cable is 1500 metres and have been told a maximum of 30 amps, doing cable drop calculations I'm coming out at over 95mm swa??? I must be doing something wrong? my heads hurting!!
Calculate for the actual current draw not the absolute maximum, 30 A sounds a lot for 5 cameras but perhaps they are PTZ. Run the cable as a ring if possible to reduce volt drop.
I think the solution might be to run a 230v ring, then a small local psu at each camera location?
Current will then be so low, volt drop will be negligible
just cameras, apparently they are roughly 5 amps per camera, but i have since found out that each column will have a poe that converts to 24v ac
Reply to CCTV cable drop in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
all currently working towards my 2391 c&g I&T . I know how to calculate v.d. but the mock test I found online seems a bit out of date or I'm...
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
