Discuss CCTV - TV system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi Guys...didn't know this forum was here. I've had very good advice from Guys in Electrical Forum in the past. I'm installing CCTV and TV system.
ALL TV cables in loft space. All CAT 5 cables from same TV points (just in case needed at a later date) in ground floor position. All CCTV cables in same ground floor cupboard position. I would like to link the two together. What cable (s) would be required from cupboard position to loft space to achieve this.
I'm thinking of installing a sound system also. Sorry for basic questions, but I'm doing this as a favour for family member. Many Thanks
Reply to CCTV - TV system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Electrical2Go - Beginners Guide to Positive Input Ventilation (PIV) Units: A Solution to Indoor Air Quality Woes A guide to Positive Input...
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
I went to look at mess this morning. S plan heating system, google nest heat link in airing cupboard. Downstairs in utility room the kitchen...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
