Discuss Ceiling Downlights in the UK Electrical Forum area at ElectriciansForums.net
Phil379
Hi,
Hope someone can help me please
Have six ceiling downlights in my kitchen, recently one of the bulbs stopped working so I replaced it, these lights have a retaining spring clip which stops the bulb from dropping down. My problem is I now have three of the lights not working, have checked the bulbs and checked the wiring all is ok. Is it me in re-fitting the spring clip not correctly? Can the lights just dangle from the ceiling and still work or do they need the clip to act as an earth?
Any info/advice would be greatly appreciated
Many Thanks
Phil
even dangling from the fitting, the lights should still work. my guess is that you've disturbed a loose connection thus stopping the 3 lights from working. as they are daisy chaied, a break in either L or N conductor will stop any lights further down the chain from working. if you're not confident to find this, call in a spark. simple job should not take more than an hour.
Hi Phil,
The clips have absolutely nothing to do with the functioning of the downlights, they are just there to keep the fittings in place in the ceiling.
I would suggest that in the act of you taking the fitting down a wire has come loose possibly in a joint away from that light and you must be careful when looking for this, proper procedures must be adhered to with regards to isolation etc.
You are probably going to need some professional assistance i'm afraid.
[automerge]1584452002[/automerge]
The clips have absolutely nothing to do with the functioning of the downlights, they are just there to keep the fittings in place in the ceiling. I would suggest that in the act of you taking the fitting down a wire has come loose possibly in a joint away from that light and you must be careful when looking for this, proper procedures must be adhered to with regards to isolation etc. You are probably going to need some professional assistance i'm afraid. Tel in first again lol
Turns out it was the transformer a cheap one from B&Q of course they don’t do them anymore so had to buy three new ones with their own transformers and now the holes are slight bigger aargh!!
As others have said about disturbing a loose connection over time with the old halogen lamps quite often the wire would have got so hot it disintegrates and just about makes until the lamp fails, then you come along take the lamp out and disturb it and it no longer works.
Just replace the transformer not the light fitting. Almost anywhere is cheaper and better than b and q also.
Will be replacing as lights were old and kept blowing, with this new set of lights they are guaranteed for 5 years and I am told the integrated bulb can last for up to 35 years!!
[automerge]1584521971[/automerge]
You probably have to register the purchase to get the guarantee but they sound better and won't run as hot either
All done and working, bit of a balls ache going up and down into the loft (live in a bungalow) but wiring all done and lights look great. Just a bit of plastering to do around the lights to tidy it up, really pleased, thanks everyone for your help and info
[automerge]1584548010[/automerge]
Kept receipt from store and told to come back if any problems
[automerge]1584548555[/automerge]
Just one final question, I have loft insulation, is it ok to place it on to the lights or do I need to cover the three lights first?
Should say about the insulation in the instructions or manufacturers guidelines. Usually it's a no but they are a few leds which can be
always advisable to leave a space clear of insulation around each light, a circle 8" diameter, unless the MI specifically say that they can be covered
Reply to Ceiling Downlights in the UK Electrical Forum area at ElectriciansForums.net
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
I have 16 ceiling spots to be replaced in a room being repurposed as a bathroom. Some will be over a shower, basin and bath hence need to be IP65...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
My bedroom light stopped working. The ceiling rose looks fine. No other lights are affected in the property and the fuses have not tripped. The...
