Discuss Ceiling Fan Wiring in the UK Electrical Forum area at ElectriciansForums.net
Mission7
I move an old ceiling fan to my carport. I wired the fan in as I took it out.
PROBLEM: at the wall box i am wiring a singe pole switch, but when ever i plug in the electricity it pops the breaker. However, when the fan is direct (hard) wired it does not trip the breaker and the fan operates correctly. I am using the same power supply in both cases. The switch is new from the store.
QUESTION: why does the switch cause the breaker to trigger and direct wiring does not?
Can you show a pic of the switch wiring.
Mission7 where you put the ceiling fan should have at a minimum of 2 cables having said that 1 cable you have a black and white at the switch the white wire is supposed to be taped with black tape to indicate it is being used as a live wire. The main cable power also has a black and white. That white wire needs to be the power for the light which is coming from the switch. All you have done is terminate the white from the switch to all the white wires or neutrals so when you turn the switch on it trips the breaker
Ok, let me decipher this comment. A single pole switch gets a white (hot) wire from source to fan. The black wires are not used and the ground wire is wired to ground on switch?
Mission the hot black wire in the box with the light goes straight to the switch top screw the white wire in the switch goes straight to the light. If they are more cables in the box should be all tied together. Please tape the white wire being used as a live wire
Reply to Ceiling Fan Wiring in the UK Electrical Forum area at ElectriciansForums.net
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
Having trouble figuring this one out. House was built 5 years ago. Eaton box and breakers. Over the past 3 weeks, the bedroom breaker keeps...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
My ceiling fan does not have light. couple of weeks the light started blinking then it went off. I did my search and everyone says that I need to...
