Discuss ceiling light/fan cable in the Lighting Forum area at ElectriciansForums.net
will be fitting a new ceiling light/fan, can I use the twin and earth lighting cable already fitted, ore will I have to fit 2.5 twin and earth cable. the specifications are fan 42w. lights 3x40w, total 162w. many thanks for any help/advice.
Welcome to the forum mate.
162W will be ok on the lighting circuit (Less than 1A), so you don't need 2.5mm cable.
What room are you fitting this?
As stated you should be fine with the existing
Now a question off me
What on earth has driven you to go fitting a miniature helicopter in your home
Personally I don't mind taking them out but I find it mind boggling when I am asked to install the same:)
Before fitting your new light/fan, take a picture of the existing wiring to the existing light. Label up each wire and what terminal they go to. This will help you with the wiring.
Please make sure the circuit it safely isolated before fitting the new light/fan.
Glad we could help.
Now you might realise these big fans are just there for dust to land on. Cleaning them is a bit of a problem.
Especially if you don’t turn them off first.
Reply to ceiling light/fan cable in the Lighting Forum area at ElectriciansForums.net
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
I have a spare 2.5mm 3 core flex cable. Can I use it for an outdoor light? It will be connected a junction box that's already supplying...
Im running a ring main for all my sockets using 2.5 cable....as an after thought i was thinking to spur off one of my socket outlets and run up...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
