Discuss Ceiling Light Fixture in the UK Electrical Forum area at ElectriciansForums.net
S
Spinney
Hi, I'm hoping someone here will be able to help. Recently the ceiling light in the sitting room fell down and was hanging by the wires. When I took it down I noticed there was a long nut which had fractured. It's like an extension nut but has a hole along one side for the wires to pass through. It attaches the light fitting to the ceiling mount. I've tried to upload a picture of it but it keeps failing, I think I need to do 6 posts before I can upload things.
I've not been able to find one anywhere and I dont even know what they're called:blush5:!
Any help in finding a replacement would be much appreciated.
Neil.
without a pic, we're struggling. there are so many different types of fixing. might be a better idea to get a new fitting. they're cheap as chips these days.
pic should be low resolution. only a few kB.
Try a hosting site such as photobucket.
Right, finally managed to get a picture uploaded, thanks for the advice.
This is the nut that's causing me so many problems:smilewinkgrin:
Take it into your local Lamberts or similar engineering hardware stockist and I'm sure they will match you up with something similar. Any idea what the thread size is?
What is the purpose of the gap ? can you "spot" three nuts together cutting the middle one in half if you need the gap?
I think he needs the gap for some of the wires to pass through. A longer nut could be adapted if a "V" were cut into the mid section. My only concern is that it's a non-standard thread size.
I thought that about the gap. I think the threads are probably metric, depends on how badly he want's the fitting and if he has a tap and die set lol.
Yeah it's hard to say , looks like it has had abuse to have snapped like that , easy enough to thread a bit of tube and and make one up though if you have the gear.
I would tend to see if you could find a coupling nut of the same thread and drill a hole in the side for the cable. I think cable barrel nuts would not come in the required size.
As Guitarist says, probably a special, I have not seen one quite like that before.
Though I do think I have seen something but I think it was an externally threaded rod not internally threaded.
Most of them are , I just hate them. Especially the types with the two flush side screws. Sooner wire a 10mm shower switch in a dark corner lol.
Could be BSF/BSW but the flat on the threads could be American Sellers thread which is very similar to Whitworth. Very odd, cast nut with an inherent weak spot.
Thanks for all the input.
Its a standard 10mm thread. I took it to a hardware store today and the gentleman there was very helpful but hadn't seen anything like it before. He's given me a much stronger brass fitting as he agrees it's a very poor and brittle design, like Guitarist he was 'cynical'! There is no hole in it so it will require drilling, which could be challenging.
Reply to Ceiling Light Fixture in the UK Electrical Forum area at ElectriciansForums.net
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
I am adding a light fixture in a room I am restoring in my 160 yo house. I have ran a new 12-2 w/ground wire from the ceiling box to a junction...
