Discuss Ceiling light not working in the UK Electrical Forum area at ElectriciansForums.net
Paulm962
Hi there.
We live in a new build changed the old ceiling light over for new fitting and it’s not working. I attach the light switch which I changed faceplate(maybe done this wrong) and the cables coming out the ceiling
problem lies with the switch, one of the brown wire should be in the terminal that is currently empty.
POWER OFF BEFORE ANY WORK.
Two brown wires needs to go to COM, other brown to L1 and whats most important earth wires green/yellow needs to be connected to earth terminal in your switch
Well spotted,
Missing earth is a danger.
If you have changed any other switches,I would urge you to get someone qualified to check them over.
Easy mistake as some manufacturers label the terminals differently. (L1, L2, L3 instead of C, L1, L2)
As above... make sure the power is off. Can get a nasty kick off a lightswitch
Reply to Ceiling light not working in the UK Electrical Forum area at ElectriciansForums.net
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Sorry no photos, but I’ll explain best I can. Turn on the switch, I’m not getting any light. Apparently a new fitting. Description…. A white...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
