K
KCarter90
Hi all,
As stated, currently having a problem with my ceiling light. I recently went about trying to change my ceiling fixture which I have never had a problem doing before. as far as I'm aware minimal wiring is required and the job is relatively straightforward forward.
Now, the lights don't work. both living room and bedroom (I live in a flat and these are the only two ceiling lights).
The RCD switch on the fuse box turns off & will only remain on if I switch the 'lighting' switch on the fuse box.
I have attached a couple of pictures. basically, the live and neutral wires you see, I wired those to the corresponding parts on the light fixture, but it's just now working. it did work, briefly a few times & I put that down to loose wires (the fixture did not have a brilliant means of attaching to the ceiling). So it would turn on (then presumably the wires would come loose) & lights off, RCD switch off. So I swapped it back to a very standard light fixture thinking it'll have no problem working. But nothing.
If anyone can assist that'd be great,
Thank you.
Thank you.
