Discuss Ceiling recessed down lighters in the UK Electrical Forum area at ElectriciansForums.net
cut a couple of 2 ft. sq. holes in the ceiling and fit 2 of these.
49889:sunglasses::sunglasses::sunglasses:
A 50W lamp gives off the same heat be it 12V or 230V
If you must fit halogens, fit 230V jobbies
had this argument with a lighting "designer". customer wanted smart lighting, whole house was approx. 120 downlighters. the "designer" specced 12V LEDs each with drivers. my input was "youse going to have problems". customer went with the designer's spec. and now is calling them back in to failures on a regular basis. he called me and asked if i could sort it out permanently. my reply was to rip out the £2000 he'd spent and start again from scratch. was not well received.
Cons.
6 halogens at 35W each (or 50W if you really want to burn your head), that’s 210W.
If they’re sitting under that, they will feel the heat.
Compare that to 6W LED and the energy saved alone will pay for the installation.
Halogens need replaced more frequently.
The heat from halogens can deteriorate the plasterboard ceiling
Pro
As above, halogens don’t flicker as LED do, but that’s almost imperceptable.
Halogens can be dimmed simply with traditional dimmers and newer smart switch dimmers.
LED lamps are still a little hit and miss with suitability.
I take it you mean the LED version of the old 12v dichroic? might of well had the GU10 type.
Sorry that was a reply to Tel's post 26 not got used to the new forum yet
OK , just spoke to the client , he said he wanted 240v halogen spots , citing that led's light is not as good as halogen , we have agreed to fit the GU10 fire rated holders and I will show him both types fitted so he can see the difference !
Aren't these halogens being phased out now?
The LED light is only as good as the quality of lamp you but.
Cheap Chinese tat - cr*p light
Decent priced from known manufacturer - just as good as halogen
And you have the choice of colour temperature
But my original question was about regs for fitting , not whether or not my client wanted halogen or led spots !
These halogens get to approx 200 degrees C. so keep a distance away from anything combustible i.e. wooden joists and other fabric of the building.
Make also sure that there is no other debris ie rubbish that could cause ignition of a fire.
Consideration of building regulations would be a transmission of sound, fire and air through the hole.
Reply to Ceiling recessed down lighters in the UK Electrical Forum area at ElectriciansForums.net
Hi, want to installed some LED strips in the ceiling and wanted to know how the recessed LED profile is fixed in place and stop the plasterboard...
Had a customer message me before I went to do a job asking if I could put a new bulb in a spotlight while I was there, so I picked up some LED...
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
I have 16 ceiling spots to be replaced in a room being repurposed as a bathroom. Some will be over a shower, basin and bath hence need to be IP65...
Hi. Looking for some guidance please as I’m wanting to replace a ceiling rose fitting into a ceiling pendant. Done this many times but never come...
