Discuss Central heating fault. in the Central Heating Systems area at ElectriciansForums.net
So a customer changed his own stat and wired it wrong and blew 3/4 fuses. Then heating was stuck on so I changed the programmer and this resolved the problem so I think the short circuit had damaged programmer.
Now 5 days later the the hot water isn’t heating haven’t been yet. All I can guess is the cylinder stat or zone valve could have problem.
Any ideas?
Did you test it first before replacing it or was it a bit of guesswork?
How do you think a short circuit may have caused damage to the programmer?
The live at room stat was permanently live regardless of the position on the programmer. The programmer was always calling for heating even when In off position. So I tried a new Drayton programmer and heating was fine.
You need to do some live testing.
Is power going to the stat when calling for heat?
Is power coming back from stat when cold?
Does manually opening the zone valve bring it on?
A major short circuit may have damaged more than the programmer, but you need to test thoroughly rather than playing parts bingo.
Do you know what the customer had done? If he wired the stat wrong, I would expect this stat to bear the brunt of any fault, not the programmer some distance away….
I suspected the programmer as the room stat was still live when the programmer was off.
I will check those things you said.
Seem the hot water 2 port valve is also faulty. It moves accross but it doesn't make the orange become live so the boiler isn't firing up. So hopefully this is it fixed once I get hold of a new valve.
thanks
Reply to Central heating fault. in the Central Heating Systems area at ElectriciansForums.net
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
i , i have a property to work on which has a programmable room stat upstairs and a programmable roomstat downstairs. S plan system , 2 zones. hot...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
