Discuss Certification needed for replacing a light fitting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Do I need to provide a minor works certificate, or any other certificate/test results, if I replace a faulty light fitting which is connected directly to the circuit wiring?
Also, will any tests be required if I change a light which is connected via a 'rock rose' and if I replace a faulty battery in an emergency light fitting?
Well answer to all 3 is no .....................what is a "rock" rose ?? Apart from a flower
Whether you want to issue one, or test the circuit to make sure it is safe ................after your work is down to professionalism
And also limiting your liability to the exact part of the installation that you have worked on.
Until about 3 years ago Peter's of Durham did the best cheese and onion pastys. Then they changed the recipe and about a month ago went bust:(
Reply to Certification needed for replacing a light fitting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
