Discuss Certification Query in the UK Electrical Forum area at ElectriciansForums.net
Hi there hope someone can help . what certificates I should be issuing if any for the following remedial works to a unsatisfactory EICR on a rental property : 1/ installing RCBO devices to replace MCBs to lighting circuits .
2/ changing a single socket outlet on an immersion circuit to a 20A DP switch
3/ changing an incorrectly installed twin socket outlet to a cooker control switch that’s still controlling a double oven. Am I right in thinking that no certificates are required because non of the work has changed any aspect of the wiring . Thanks all
as he says^^^^^. you are altering circuits, so Minor works for each.
Reply to Certification Query in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi all, I'm about to replace our kitchen and one of the upgrades is to install two full size ovens to replace the original twin over under...
Hi Everyone, I had a new consumer unit installed in December 2021, the electrician said that he had more testing to complete and would come back...
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
