Discuss Certification software in the UK Electrical Forum area at ElectriciansForums.net
Pip
Hi People,
So at the moment I use the Elecsa certification software, on the Niceic/Elecsa/certsure website to complete my certificates, easy enough.
But can't access it offline and fill in the forms while on a job, (well I must admit I've never tried but without internet don't think I can?)
So what certification software do people use which can be filled in onsite so that I don't have to spend hours entering the results online back at the office.
Thanks in advanc
I'm another Easycert user but I'd be interested in seeing some other recommendations.
It's great for doing a basic cert but I haven't found a way yet to customise the certificates to let me add more columns on the results page
More columns on the results page? how many do you want? And what headings?
I want to add the RCD type in as when I put B (A) for the RCBO types, the max Zs throws its toys out of the cot. I'd also like to change the R2 for rn + r2
OK I see the max Zs not needing to throw a wobbly, but R2 for rn + r2. any test reasoning you would need this figure?
We measure the rn + r2 as part of the test sequence but don't record it. It's more a personal preference to have it.
I've just remembered I'd like another column as it only has one operating time for RCDs I'd like a separate 1x and 5x but that's just me getting greedy ?
I contacted EasyCert about this and after asking why I wanted the extra columns they told me they had no plans to update the software and in any case the form is the Standard everyone use's.
However if you export the report as a PDF you can modify it how you want, by adding in a text box putting in your own text or putting the text box inside an existing box and white filling which blanks out the original text then text on top, have not found a way to put an extra column in yet, but have not tried that out.
Easy cert as well, it does everything I want it to.
Rrn +r2 should be included, how many times have I seen badly damaged switches on neutral. Only last night i was on a call out at 3am, fire brigade has turned power off, the smell came from between floors. Neutral loose as... cable burnt, floorboards charred . I think they were very lucky
Reply to Certification software in the UK Electrical Forum area at ElectriciansForums.net
Its time I bit the bullet and got some proper certification software, I've used my own forms for ages now which I spend pre-filling everything in...
Not sure whether this is the right context or even forum to mention this, but I’ve recently been offering out myself to a friend to help get his...
Hi Everyone, I had a new consumer unit installed in December 2021, the electrician said that he had more testing to complete and would come back...
Hi, Have been using the NICEIC software, but doesn't work without an internet connection. Many of our jobs are in areas with no mobile...
Hi everyone, does anyone have a link for a free EIC template? I work for a solar company working on solar farms, I had to install a new DB today...
4K
