Discuss Changing a 2 gang socket to a 4 gang in the UK Electrical Forum area at ElectriciansForums.net
SiJohn
Hello all,
Just wondering what is involved in changing an existing 2 gang socket to a 4 gang outlet?
Is it a case of using the existing wiring from the 2 gang.
why not just add another 2 gang alongside? and yes, just spur off existing as long as it's currently on a ring.
as long as you only spur off 1 socket (single or double) it complies. more than 1 socket spurred off should be fused down @ 13A.
Wiring Rules in the south of Ireland don't permit unfused spurs. That said, rings aren't terribly common there. More likely to be a 20A radial.
Th
Thanks everyone for replies. In the end I added a double gang to the circuit and from this I added a spur with 13amp fuse switch . There are two double gang sockets running on this spur. Sobto recap I added three double gangs. Thanks
Reply to Changing a 2 gang socket to a 4 gang in the UK Electrical Forum area at ElectriciansForums.net
Hi, just hoping for a bit of advice. When I travel abroad (Europe, predominantly Spain/Cyprus) I usually take a single travel adaptor and a UK 4...
Is there such thing as a 2 Gang flex outlet plate, changing an existing heating system to a nest so no need for the programmer however it is by...
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
