Discuss Changing bathroom light fitting like for like in the UK Electrical Forum area at ElectriciansForums.net
I supply bathrooms and wondering where my fitters stand with changing a bathroom light. They are competent in electrical work however they aren’t electricians. Are they ok in simply changing the bathroom light like for like?
debatable if only a like for like replacement.
Suitably rated fitting for me.
[automerge]1581879400[/automerge]
so a like for like electric shower which has rcd protection already... can a competent fitter change this too?
If suitably competent, yes.....but I've seen some real cock ups in such situations.
edit. A good example in post below.
Along with this....
depends on competence. once went to a shower that had been changed by a wet pants who thought he was competent. due to the configuration of the new shower, the 6.0mm cable was too short to reach the terminals, so he joined a bit of 2.5mm with the sheath stripped off to the 6.0mm inside the shower. twisted and taped. he called me out when the 30A 3036 kept blowing. his joint was fused together, all 3 conductors shorted.
Reply to Changing bathroom light fitting like for like in the UK Electrical Forum area at ElectriciansForums.net
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Hi folks, Quick query for this still practicing regarding bill payment for a job not complete. My partner recently employed an electrician to do...
In my bathroom there is supplementary bonding of the bath, bath pipework, and basin pipework before it goes into trunking and exits unconnected in...
I have 16 ceiling spots to be replaced in a room being repurposed as a bathroom. Some will be over a shower, basin and bath hence need to be IP65...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
