• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Discuss Changing garage Mcbs for Rcbos in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
My garage has a small consumer unit fitted with elcb and mcbs for the socket and lights. After cutting through a circular saw cable it did not take out the garage elcb but the elcb in the house consumer unit. If I get an electrician to changed the mcbs for Rcbos would this prevent the house elcb tripping should I be so daft to do this again. If you don’t think this is suitable what should I request to the electrician to be done.
You have two RCDs in series, this is a poor design and really needs correcting.
Not dangerous but annoying when you have to walk back to the house to reset and it also takes out other protected circuits in the property.
get a spark in to change the garage off the elcb to non side . but keep the garage on its own elcb .
Ill ask elect to do that
thanks I’ll get him to do that
well at least the cost of repairing /replacing the cut cable is a cheaper way of testing a RCD than buying a "proper" tester.
Reply to Changing garage Mcbs for Rcbos in the Electricians Jobs area at ElectriciansForums.net
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Hello, I have a hypothetical question (I'm an electrical engineer) to better understand RCBOs and how they are used in the USA. Let's say I would...
Hello sparkles, I have a question in relation to sequencing the RCDs and MCBs in the CU. I called an electrician to come to my house and upgrade...
