Discuss Changing hall ceiling light affects bathroom light in the The Welcome Forum area at ElectriciansForums.net
I have taken down an old hall ceiling light and I have 3 wires which are the same grey colour. Whatever way I rewire them to the new light fitting it affects the bathroom light. If I wire them in one configuration I can have the hall light on or both the hall and bathroom lights on at the same time but never the bathroom on its own.
The wire that I have:
Wire 1 will be live when I turn on the hall switch
Wire 2 will be live when I turn on the bathroom switch and have a working light bulb in the bathroom.
Wire 3 does not light up with the phase tested at all so I assume it is the neutral wire
What I have wired at the moment:
I have wire 1 wired into the Live section of the light
I have wire 3 in the Neutral Section
The hall light works fine. I have tried wire 2 in the Live/Neutral/Loop section of the hall light fitting and I either dont get the bathroom light working or it will only work when the hall light is switched off. I feel light I have tried every combination but I am obviously missing something.
The new light fitting has 1 Live, 3 Loop, 2 Neutral sections empty. The old light fitting seems to only have 1 Live and 1 Neutral.
Many thanks for any advice
Need some pictures. Don't suppose you took one before you disconnected it all.
Unfortunately I didn't get to take a picture before I disconnected the old one. I normally do but I had to cut the old one down with a Dremil as it had been plastered and painted into the ceiling over the years by the previous owner of the house.
Here is a photo of the current setup.
If the wiring at that ceiling rose affects the bathroom light then something seems wrong at that rose. They all appear to have red insulation but I suspect there are two neutrals and a switch line return.
That's what I was indicating, above. I don't like giving answers to the uninitiated, just the odd clue.
Seems like it's in Ireland, a diy job...…..ask Risteard?
I have managed to solve the issue. It was a shared neutral wire coming from the bathroom. I thought it was a switched hot wire because I got a reaction from the phase tester.
What gave a clue was that I had to use a working light buld in the bathroom to get a reading on wire 2 which lead me to think it was a return neutral wire from the bathroom rather than a hot switch wire like I thought.
Terribly sorry Old Chap.
Reply to Changing hall ceiling light affects bathroom light in the The Welcome Forum area at ElectriciansForums.net
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
