Discuss cheap 12V garden lights! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
aidge
Got called out to look at 12V 20W plug and play garden lights with MR16 lamps that are working at varying levels of brightness. Before i start taking everything apart anyone got any ideas on what would effect the lumin output of different lamps on the circuit or is it likely that its just down to a cheap set performing at different levels?
at a guess, poor connections to the fittings. either the pins on the lamps corroded, or, some are spiked onto the highway cable just by spiking through the insulation. these give terrible connections.
corrosion is always a huge problem when you get 12V and damp combined together. might think you've found a CuSO4 mine.
Reply to cheap 12V garden lights! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi Guys n Gals, I'm a little stumped on a job and was wondering if anyone could advise? I've got 3 drivers going to 3 sections of garden lights...
We're in the UK, 240v lighting feed. We have replaced all the lights in our house with LED ceiling panels. These are pretty much the standard...
Hi, Years ago we had a sparky install some 240v garden lighting but to one of the points in the garden that we wanted lighting in he only...
5K
On two occasions recently when changing light fittings I've been bored enough (after fitting the light naturally), to read the instructions that...
