Discuss cheap consumer units in the Australia area at ElectriciansForums.net
diditrain
Hi there, my first post on this site, but i regulary read the interesting posts from others.
Does anyone fit the cheaper plastic consumer units?
I fit them from time to time as required in my current position but i was wondering what anyone else does to maintain the IP rating when using the pre-formed knockouts on the sides of these consumer units for the tail entry?
I was used to fitting metal clad only with a gland in my previous employment, so these are a bit of a come down for me in terms of quality.
Thank`s for any replies/suggestions
cant remember the name of it but if i need to maintain ip4x i just use some of that brown sticky stuff thats wrapped in grease proof paper and splodge that in
that brings back memories , i used that to waterproof terminals in motors once .
the motors were submerged for a couple of weeks due to flooding when they came back from rewinding that was the the chosen method to protect the terms
Reply to cheap consumer units in the Australia area at ElectriciansForums.net
Hi, The `power went out throughout the house this afternoon but only to the sockets, the lighting circuits are all fine. I went to the consumer...
Hi all! I'm not a spark but know enough to be able to install off grid solar etc. I've just purchased a new house and have noticed the consumer...
5K
I had a PV system installed by a local reputable manufacturer last autumn; since then, I've received conflicting advice regarding the consumer...
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
