Discuss Cheapest heating in the Central Heating Systems area at ElectriciansForums.net
Hi, welcome to the forum, your down as a trainee, may I suggest you apply for access to our Trainee forum where we have selected Mentors that could help you and benefit your learning curve.
The cheapest form of heat is free, from the sun - lots of large, good quality windows will maximise thermal gain, plenty of thermal mass, so highly insulated concrete floors - combined with at least triple the amount of insulation recommended within current building regs.
A well insulated home needs next to no heat input.
Reply to Cheapest heating in the Central Heating Systems area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
  • Locked
Hi, I realise this is an electrical forum and not plumbing, but was wondering if somebody could help. My heating is not working and the heating...
4K
I'm in Raleigh, North Carolina and have a well for my house's water supply. For some reason, pitless adapters, which allow all piping to be run...
Hi all, I was thinking to use heat shrink to strengthen usb cables where the cable enters the connector. I find the insulation starts to crack...
