Discuss Cheapest Multimeter (low ohm in the Electrical Tools and Products area at ElectriciansForums.net
thMegger BM221 is what I use when I don't need all the functions of a MFT. e.g. when fault finding.
As above, don't buy cheap ebay tat if you want reliable results.
I have one of these (I think, need to check actual model):
Works very well and I prefer it to my MFT for general use, but if buying new you are half-way to MFT cost anyway, and you will need the other capabilities such as Zs/PFC and RCD testing in due course.
Reply to Cheapest Multimeter (low ohm in the Electrical Tools and Products area at ElectriciansForums.net
Chaps - having problems with a new Megger MIT420/2 insulation/continuity tester 'oscillating' and failing to give stable resistance readings in...
Hello, I have an all-in-one washer/dryer unit and it is giving me error codes. I have the manual that describes how to test the various...
Hello everyone, friends. In cases where I do not have a clamp meter, I want to measure the current drawn by the phases of a 3-phase motor with my...
The MS8268 multimeter has worked fine with no issues, but it's been in a drawer for several months. Batteries had corroded, but the contacts...
