Discuss chnaging CU in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
E
electrician4u
I've got to install a CU for an old fusebox.Problem is, there's not enough space for a split load CU.As I've only got 7 circuits, is it alright for me to put a unit in with 1 RCD that protects all the circuits?
Split load unit with 2+ RCBOs (pref sockets, then lights) pending what budget allows
Remember it's notifiable work and something something the main cut out fuse and search engine :wink5:
Why is it notifiable ? OP hasn't stated domestic dwelling it could be in commercial shop to which Part P doesn't apply ?
J
You can of course but it won't be to current regs, why are you changing it, whats the need here. There are different shapes and sizes, you can extend cables, there is usually a solution.
BTW - whats the latest on the kitchen ?
According to that website the OP has 30+ years experience and is an NICEIC Approved Contractor. And he's asking this sort of question?
Richy, the op also asked about MCB size for a 1mm socket circuit in a kitchen, which is why I asked the question. I didn't realise he was NICEIC registered with over 30 years experience, so I withdraw my earlier question...
^^^ Hi Guitarist. Yeah I read that thread first. Makes me shudder to think. Even a Electrical Trainee knows that a FRC wired in 1mm flex doesn't sound right.
No, Sector and Wylex do dual boards with 4+3 ways so maybe they'll fit.
- - - Updated - - -
But no home or office address - alarm bells ringing.
I do like the prominance of the football results!
This is a wind-up surely ??
3 clueless threads by the same "nic AC with 30 yrs exp" ?
yeah right , wake up and smell the coffee boys lol.
Edit ; this has got plumbers trolling written all over it ;-)
Im changing it cos the old fuseboard has had it.50 year old rewireable fuses falling to bits.I never said I was a NICEIC contractor. I've been an electrician for 30 odd years but not so much domestic.Just out of curiousity, why do they sell single protected RCD units if they don't comply?As for the 1mm flex on a ring, I didn't put that in, I'm trying to correct it.I've now told the customer it's gotta come out and be done correctly.For those who don't want to answer the question and simply trawl through threads to send smug comments, why bother?
Reply to chnaging CU in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Hi, I have a job for a customer, the consumer unit is an old 3036 board and there are several holes in it giving access to live parts, I can...
