Discuss choccy block / connector strip question in the DIY Electrical Advice area at ElectriciansForums.net
T
Tim Nissen
hello
I have a ceiling spotlight trackbar which uses an inbuilt choccy bar as its connector. Trouble is it is now quite old (20 yrs+) and the little screws in the choccy block seem to have lost their grip and just spin around so they don't grip the copper wires anymore, nor can I remove them. Is there a trick I can use to make a good connection some other way?
Thank you for reading this
tim
It's a maintenance free method of connecting cables. Be very careful, you may think a lighting circuit is easy but it can and will bite you on the backside.
Tim, just switch the power off for the house cut the cables as close as possible to the old connector block strip the cables and re wire. probably better to do it one at a time so you dont get mixed up. You dont need to be an electrician to do this just common sense make sure that no one will switch the electric back on put a big sign on the box saying you are working, dont presume people know. If the wires are to short you could probably take the fitting down and take it to a local electrical shop to be re-wired. Be careful and you should be ok with this simple job.
as mayfair. isolate. cut close to connector. re-strip 1 at a time and fit new connector strip.
problem is connector strip is built in to the track and permanently so cannot be replaced seperately. unless i'm being an idiot i will check it out again thursday thanks anyway for input thus far. to be resumed?
usually, the connector is secured to the fitting with the earth terminal. if it isn't, then you'll need to by-pass it.
Reply to choccy block / connector strip question in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
I'm installing a 100 Amp Sub Panel about 3 feet away from my 200 Amp Main Panel. The SubPanel is a Cutler Hammer BR2020B100V and it comes with a...
Brook Crompton Parkinson single phase PD90S (from the 70s) 240v 11A 2850rpm 50hz I'm using it for polishing metal with a tapered spindle...
5K
Im taking my AM2 on Monday and have a few questions just to get my testing on point. Firstly when testing continuity of cpc would a the assessor...
5K
Thought this might be of interest and use to anyone looking to undertake the various short training courses. So here is my recent experience -...
4K
