Discuss Choosing the correct driver in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
the driver on my saxby decking lights has failed. It's not repairable so I need a replacement.
The Vega one (picture below) is specifically for these lights and is £22 + delivery. I think that is too much and so I found a 12v 1.25A transformer at home. Cut the connector of the one and mashed up a temp supply. All the lights work however there is a noticeable flicker. I think this is due to the fact it is not a constant voltage transformer.
would this transformer be ok as a replacement?
thanks
View: https://www.amazon.co.uk/dp/B01MQJR6K9/ref=cm_sw_r_apa_i_tp1IEbDH49PW1
Reply to Choosing the correct driver in the UK Electrical Forum area at ElectriciansForums.net
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
Hello ! I am building for some time a cct to drive a 3digit multiplexed LCD. (from aliexpress) From the sellers on aliexpress I managed to find...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
I have bought some net led lights that are permanently installed outside. The problem is, I don't have an outdoor socket. And the socket in the...
4K
Hi all. I know this is probably a stupid question but this isn’t my forte and I’d rather not waste £20 unnecessarily so thank you for any help. I...
