Damian Petsas
Hi guys, Ive just come from a house to loo at a outbuilding they have. Its curently fed from the house C/U. The C/U main switch is a 80 amp rcd switch. The Outbuilding is fed by a 6mm armoured with arun of about 15 m off a 15amp mcb. it goes into to outbuilding to a 13 amp spur. From the SINGLE spur it feeds 3 radials 1 to 2 double gang sockets, the second to another 2 double gang sockets the the third to a lighting circuit of 4 lamps.
Seriously not right!!!!!......
If i was to remove the first radial and allow the second radial of sockets and spur off that for the lights supply would that confirm to bs7671.
Would it be more practical to install a garage board and break circuits down from that and uprate the supply mcb to 30amp (its a old board)
your advice and knowledge would be most helpful..
