Discuss Class 2 metal fitting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Bought 2 metal wall lights arrived today and just opened them.
They are completely metal in construction states on the fitting they are class 2 and have no earth connection.
The cables leaving the chocbox inside to the lampholder are single cores.
How can this be class 2?
The top hole leads to the lamp the bottom to one of those twisty spiral bedside lamps you get in hotel rooms.
Yeah it is sheathed at the top but not the bottom and neither are the brown and blue you can see.
I've seen fittings like this before. The wedge shaped spotlights for under kitchen units. Marked as Class II, but wholly metallic. One loose cable and you've got a live metal block, easily touchable.
Cannot be classII unless the connection is made within a plastic box, within the metal fitting.
Reply to Class 2 metal fitting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have had these lights installed by a contractor whose work is normally very good. He has not connected the earth in each fitting as there is a...
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Old two core cable in a lighting circuit with no cpc at any point All points had metal fixtures and fittings class1 At two points the live loop...
Am I the only one who loathes these connectors and just removes them immediately Apparently they also turn a class 1 light fitting into a class 2...
4K
