O
oldtimer
Hi guys
Looking for a bit advice here I have just moved into a flat that has a Clearline V210 solar system that is meant to heat up the water in the immersion but on a day like today the return from the panels is very hot ie hot enough so you cannot hold on to it suspect 65oC now the water going into the cylinder is hot coming out is cold or ambient thing is I dont appear to be getting a good heat exchange.
Now to give a bit of background on me I have worked with HVAC /BMS controls for the past 25 years only thing is I have never been exposed to this type of technology so my thinking is is this system meant to raise the water above ambient and if so what should it be ?
thanks for any help
thanks for any help
