Discuss Client refusing spd in the Electrical Forum area at ElectriciansForums.net
Little old lady has lived for 80 years and has never once had the above problem, nor does she know anyone who has. And neither do I. Why? Cos it happens so incredibly rarely that the risk is negligible. Also, little old lady is on state pension, so has very limited funds and does not want to spend unnecessarily, £70 is a lot of money to her. She wouldn't like to learn that her electrician was mis-selling her unnecessary items.
SPDs are there to help protect sensitive electronic equipment, I have not heard of them being touted as protection against direct lightning strikes of the magnitude that would destroy fixed wiring. Where are you getting this information from?
You're misrepresenting my argument. IF a surge event happens, and the SPD protects £5k worth of equipment (which it isn't guaranteed to do BTW), then it was money well spent. However, the odds of it happening are so incredibly slim as to be negligible. And even if they weren't, who am I to make that decision? It's up to my clients.
Without a link to back this comment up, this smells of fertiliser.
Why? Why should I make my clients spend £20 more than they have to, if they don't want to? If £20 is nothing to you, then send me £20 now.
This is a truly absurd comment.
Out of interest, before the 18th edition, were you forcing these oh-so incredibly important SPDs on your clients?
I don't know anyone who has had their house burnt down, nor do I know anyone that knows anyone.. I guess I don't need to bother having smoke alarms. I also don't know of anyone that has been injured or killed by an electric shock where they don't have RCD protection.. Guess I don't need RCD's.. I know loads of people who used to drive with no seat belt, don't know of anyone that ever got injured or killed because of not wearing a seat belt, guess I don't need to bother with that either..
Just look at car chargers and the importance of PEN fault protection, how incredibly rare would that be, yet its still a mandatory factor, by your logic we should not bother.
No I was not forcing SPD's, the problem is they were a niche item that was very expensive, because they introduced it and now thousands of them are being fitted they have become very cheap, just in the same way RCD's and RCBO's have. Just look at AFDD, when they make those mandatory they will come down massively in price.
If a customer says they dont want the cost of RCD's is that also ok also?
Yes, of course it is. It's then your decision whether to continue......contrary to 7671 18th.
£30 or £3000, omitting SPD is not contrary, where domestic work is concerned.
The argument is not about whether they are worth it or not, it's about necessity.
I am sorry could you point where in the regulations does it state "If the end user says he does not believe the potential for damage warrants the cost of protection then it is not required"? No its a statement of fact, my point is in even the smallest house the less than £30 protection will be protecting at least £5k of potential damage. Thus the cost of protection being under £30 will generally always warrant its requirement.
I can think of situations where say room for a consumer unit is limited so fitting one would mean relocating a consumer unit or having to make big changes, so would massively increase the cost of having to fit an SPD then there is an argument.
It doesn’t and nor did I in any way suggest it does.
I detailed word for word the actual regulation ahead of this, and then added my own commentary/comments such as the section you mention, in much the same way as others have done, yourself included.
The regulation uses the term warrant and not more than/less than for very good reason, because it is not just the £ cost of replacement vs £ cost of protection which needs to be considered.
This has been mentioned by others already.
If it was it would be simple, but ridiculous; some bit of Tech cost £31.00 the protection costs £30 so the protection is mandatory, but the customer then gets a discount to £29.00 so the protection is no longer required??
There are so many factors to consider, there is no tech whatsoever – so £0 hence on first sight it doesn’t warrant the cost of protection; however, the customer knows that actually any unavailability would have severe impact to them, so in spite of the £ cost of replacement vs £ cost of protection being completely in favour of omitting the protection, in actuality the customer knows the protection is warranted.
Similarly, the customer appears to have lots of stuff, but it is provided on rent, any failures mean a brand-new replacement at no cost to the customer! – clearly this doesn’t warrant SPD protection. Alternatively, the customer has an assured new-for-old insurance policy – again any failures result in them getting new tech for free (Saves them having to “Spill” a drink into the TV)….. The list of circumstances is endless!
Who is able to make this decision – the balance between the cost to the customer based on their personal circumstances, experiences of previous incidents at that property etc – it certainly isn’t the electrician trying to upsell that can do this, it is of course the customer themselves.
Irrespective of one’s own bias on SPD being a good/bad thing the regulations make it clear, not fitting SPD in a single dwelling where the cost of protection is not warranted is completely in-line with the regulations.
As to good/bad I have differing opinions, I have SPD fitted at my own home, I recommend SPD on every job (not usually residential work – I work on larger projects usually); however, I have come to the belief that in the long term they are going to be useless.
In general SPD can only withstand one major surge, so inevitably where the protection is needed after the first Major surge (or perhaps many minor surges) the installation is back to being without a working SPD, and since at homes absolutely no one routinely checks the condition of the consumer unit on a regular basis – it would remain unnoticed.
And whilst this is my conclusion, based on the technical facts, it doesn’t change the actual written regulations, which we all must adhere to.
As for a customer not wanting RCD, yes you check whether it may be omitted in accordance with the regs such as 434.3 for example - and if the regs permit it then yes you may omit it just like omitting SPD where the regs allow it.
I think you are confusing want/likes with regulations and law, they are quite different.
Smoke alarms - no I may not know anyone, and think they are unnecessary - But they are required by LAW
RCD - no I may not know anyone, and think they are unnecessary - But they are required in some cases by the regulations
Seat Belts - no I may not know anyone, and think they are unnecessary - But they are required by LAW
Opinion is one thing, but we still abide by laws and regulations.
(And I don't actually think the above are unnecessary)
Your own logic is so badly flawed that I suggest you may want to consider retraining as a plumber:
1 - smoke alarms, RCDs, PEN fault protection, and seat belts SAVE LIVES. SPDs, under certain circumstances, save delicate electronics. Unless the electronics themselves are actually used to preserve life, there is no comparison.
2 - RCDs, PEN fault protection, seat belts, and (at least for new builds, rentals etc) smoke alarms, are MANDATORY. SPDs, in dwellings and in many other situations, are not.
I am not denying that surges happen, nor that they can damage electronic equipment. However, for most situations, the chances are very, very low, and the consequences largely insignificant - your TV goes on the blink, or your phone gives up. It's hardly life or death is it?
Let's face it, all houses have equipment worth more than £30 that could potentially be damaged by surges. Show me one that doesn't and I'll show you a cave.
I am not saying that, as said above the regs use the term warrant, not "does the equipment cost more than.."
We experience this all the time, buy a new kettle or microwave or whatever and you get the usual "do you want extended warranty for £29.99?"
You make a decision based on the cost, likelihood, and personal circumstances, yet most times the cost of the replacement would be more than the £29.99 or whatever it is, many of us won't buy it though as it's covered by our insurance, or the likelihood is so small etc
The regs recognise this, and allow a decision to be made, such a decision is every bit as valid as your or my opinions, in most cases probably more valid as the customer actually knows their circumstances.
SPD's can stop fires so can save lives
I am sorry but when you consider the damage a lighting strike can do, not just to tech but to fixed wiring, the cost of a rewire and damage to electronic devices and we are not just talking laptops etc, we are talking washing machines, fridge freezers, cookers, TV's almost everything has electronics in it these days. That is why the regs changed so they become commonplace. You are going to have to do a lot to convince me that spending £30 is not warranted.
So ok lets say its a studio flat and its rented so apart from the cooker the landlord does not own anything else so does not care... So the damage that could be caused is new consumer unit, all the accessories, including lights etc, all fixed wiring and new cooker, so lets say £2000. When the regs were written and an SPD was say £200-£250 yeah I might agree there is an argument the cost is not warranted. But when you have the cost now at £27 thats more of a hard sell.
Where do you stop, £10million pounds worth of equipment, customer says no I dont want to spend £27 on an SPD... Does that pass your test of the cost of protection warranted? For me that does not comply with the regs as clearly it is warranted. We all know if you say to a customer do you want an SPD, it will cost you an extra £5 more than half will probably say no even if they don't know what an SPD is..
I've looked at SPDs from both sides now,
From up and down and still somehow,
It's SPD illusions I recall,
I really don't know SPDs at all!
Nah! Joni Mitchelin............she was talking about the tyres on her big yellow taxi.
Just how will a standard SPD protect against a surge of such magnitude that it would destroy the fixed wiring?
Standard SPSs of the type that are being installed can only protect against relatively minor voltage and current surges, A typical SPD is 2.5kV 10kA on a 8/20uS wave.
There is also likelihood, a property that has never received any such surge in the past 30 years is most likely not going to get one in the next 20 years or whatever the expected lifetime of the installation is.
Again it doesn't matter if you are convinced or not. if the customer believes it is not warranted then it is completely in line with the regs. That's it, opinions may differ but the rules are the rules, not just when it suits you or me.
There are many aspects of the regs that I don't agree with, irrespective on my beliefs I adhere to them.
[Edit - by them I mean the regs]
This is a point I tried to introduce last night. A couple of comments seemed to suggest that a £30 Type II SPD was going to offer protection against lightning strikes, which clearly isn't the case.
I even invited ridicule, had I misunderstood their capabilities.
Reply to Client refusing spd in the Electrical Forum area at ElectriciansForums.net
