Discuss Clipsal 6 gang switch alternative in the UK Electrical Forum area at ElectriciansForums.net
Hi all , have a vile 6 gang clipsal switch which I need to change trouble is the 3 5mm pins are top and bottom none on the sides , is there an alternative switch out there that I can fit .
Cheers grand
Holy cow batman , I haven't seen one of those switches in over 20 year.
We used to get our Clipsal stuff from a little indy wholesalers in South London but they closed down over 10 years ago.
Try Ebay ??
I can think of 2 options;
Install grid switches vertically
Or
Remove the machine screws from the yokes and screw through the back box with long screws
I would just bite the bullet and price to install a new 6 gang standard back box and fit a new 6 way grid switch
It really isn't a massive job to pull the old box out and put a new one in.
A few hours labour and the cost of a new switch.
Future proofed then for the next 50 years or so...
Wonder if you can get the pre-engraved switches with 'Boom' on them?
Reply to Clipsal 6 gang switch alternative in the UK Electrical Forum area at ElectriciansForums.net
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
