Discuss Cmon guys - need help to choose fan! in the Australia area at ElectriciansForums.net
C
Cirrus
Am doing a job at the weekend which involves fitting a ceiling mounted bathroom fan. Now, any ideas on how to best switch it as the bathroom is very light so no need to have it come on with lights. Can it be independently switched from a wall outside of the bathroom? Just need some help here on what best to do and any ideas on what I can buy.
Just seen some fans with a pir built in. Looks like a perfect solution. Anyone used one?
hey mate,
you could get a descent humidistat fan so it will work when it needs to, doesnt work for number 2's tho i suppose! or why not just fit a 2g switch outside the bathroom, one doing lights and one doing the fan? then they can choose when they want it running and it can still have an overrun incorporated?
cant really think of much else really, it needs some form of switch live so.....
hope this helps
rich
just to add, so long as you take your sw/lives and perm lives and neutral to the fan iso 1st then on to the fan it will be fine
"ICON" fans are nice. maybe not the quietest but about the best looking and each on accepts different "modules" etc so you can alter how it is switched, PIR etc >
If the space allows then a remote fan above the ceiling is quieter. But ££
I've installed a humidity controlled one before. They're not cheap but you don't have the hassle of hooking up to the light switch, just a straight forward fcu . I think it came with a pull cord over-ride for selective use.
if its a loft space, then go for inline fan? or like the other lads said go for a PIR sensor for the fan. There's loads of options, but if its a high spec house then go for a PIR if its your average 3/4 bedroom, switch it on with the lights.
Yeah, think it will have to be switched with the lights or on a seperate pull cord. It's gonna be vented through the eves as no roof vents sadly
i have fitted time adjusted fans before that will not turn on late nights etc. Gone are the days of people accepting them coming on and driving everyone mad !
Reply to Cmon guys - need help to choose fan! in the Australia area at ElectriciansForums.net
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi, I am installing a new bathroom fan. We had an electrician who ran 14/3 into a junction box. The black feeds a led light and the red was...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
