Discuss Code for 'taped joint' above downlights - no access above in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Would rather have connector block wrapped in tape, than wago 221 not in an enclosure.
Came across this a while ago in a loft (loft had is own lights) while trying to figure best route to lay cable for an extension, all of a sudden I'm in darkness (didn't have torch up with me - another school boy error) as I turned around to head back to the hatch to see what's happened, I feel loose wire with my hand.
Anyway, back with torch came across these wago 221s in which a couple of levers were opened and one of the live wires had popped out.
Can only guess with my movement in the loft I had disturbed this hidden connection (insulation enclosed connection) which resulted in the levers popping open, wire popping out and (thankfully) RCD tripping - photo taken after wire reinserted and loft insulation pulled back.IMG_1797.JPG
So please please always use an enclosure, don't go trying to save a few pennies here and there, as next person may not be as lucky as me. BTW levers on 221 open very easily compared to 222
I can't see what the problem would be with an Ashley/Hager 301/401 joint box in such a situation. Done properly, with skill and dexterity, of course.
Reply to Code for 'taped joint' above downlights - no access above in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Good morning all. How would you code the following?: 1 - Electric shower installed without RCD protection, where manufacturer states it is...
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
Hi. This is a gloriously messy installation I looked at this morning at a house a friend just purchased. It t became quickly clear it was more...
Hi all Doing an EICR on a basement flat, downlights throughout. Need work as all are connector block and taped, however none of them are fire...
