Discuss Collingwood FL05 Lights in the Lighting Forum area at ElectriciansForums.net
BenBrazil
Hi,
I've just had two Collingwood FL05 garden lights fitted professionally by an electrician. They don't appear to be working however, or at least as I would expect. The PIR turns the light on during daylight. I would expect that they should only turn on when it is dark. Is this correct?
Many thanks,
Ben
Reply to Collingwood FL05 Lights in the Lighting Forum area at ElectriciansForums.net
I've a light fitting that's controlled from a Whitecroft absence detector PIR and a wall switch. The way it works, is the Retractive wall switch...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
I have carried out home wiring for 60 years as a competent person, for the last 20 years, I employ a local electrician to check my work and sign...
