Electrical2Go - Online Electrical Supplier
Discuss Combi Boiler In Zone 1! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
W
Wotsit
I have been asked to perform a pir on a property i know (belongs to my girlfriend) as we have tennents moveing in. My main concern is that a combi boiler is fitted in zone one. This was fitted about 4 years ago by a local plumbing firm.
How do you suggest i go about the rectification of this with the plumbing firm. They have just issued a landlords safey certificate.
It was intresting that they noted a undersized bonding conductor on the incomming gas but nothing about the boiler location.
Bulk Workwear - Clothing Suppliers for the Whole Forum Network
Spudnik
  • #2
Can you build a cupboard round it?
W
Wotsit
  • #3
No, the manufactures instlation instructions reccomend a clearance that would put the cupboard over the bath just where your chest would be if you were lying there.
At the monent you can look up and see the underside of the boier if you are in the bath
spark1
  • #4
Wotsit, areyou saying that the combi boiler is in zone 1; within a shower enclosure or is directly over a Bath ??????
spark1
W
Wotsit
  • #5
spark1
Yes just that, right over the bath.
spark1
  • #7
Yes , sorry, I never worded that very well I was trying to confirm that wotsit had his zones correctly identified,,,,from his last post he has verified that.
My answer to the o.p. is to issue the P.I.R. with a code 1 on the boiler. It must be classed as Electrical equipment as it contains electrical parts therefore it requires IP X4 minimum....I take it the supply circuit is Rcd protected otherwise a Code 1 or 2 would be applicable also...either way " unsatisfactory on the Report...and send the Plumbers a copy asking for their comments.
spark1
Des 56
That is probably because their electrical regs knowlege may not extend to zones and suitability of equipment
If its due to lack of space then a shower may hve to be fitted instead of the bath
What plumbers get up to, it sometimes beggars belief
G
Guest123
  • #9
In full agreement, in my book it would costitute a code 1 on a PIR.
W
Wotsit
  • #10
Do you think that the company that fitted it should, move it as the installation was incorrect? If so what do you think my course of action should be? I doubt a phone call the the installers detailing my concerns will suffice.
62patrick
  • #11
Its a code 1 in, as in all off the above posts,
Whats the date of the installation ?,
What certificates did you get when it was installed ?
Was it a replacement boiler ?
Did anybody agree to the boiler being fitted in that position in the first place ?
When all said and done its still a code 1 in my book
W
WB Scott
  • #12
Have you looked into the manufactureres instrustiions for the boiler? Is it suitable for purpose, ie does it have an IP rating?
I agree its a Code 1.
How high are your ceilings? If the boiler is above 3m then it's outside of all zones.
(I think, correct me if I'm wrong)
Mark
W
Wotsit
  • #14
The date of instlation was around four years ago.
It was a new instlation.
There is a mass of paperwork, with a safety certificate for each year
My girlfriend agreed to the location of instllation but how was she to know?
Mark
Boiler is about 35 cm above bath rim. The supply is non rcd. The fused spur is level with the bath rim, about 20 cm back from where you head is.
I would take a photo but we have tennents in there
Yes,
It is not sutable for instllation in a location containing a bath or shower. There is no IP raiting
It's definately a code1 and it is something that will have to be rectified ASAP. That would surely make any insurance you have on the property invalid. I'd phone the company up that installed it and threaten to name and shame them unless they move it. Might help!
Mark
Aico Carbon Monoxide Detectors
Reply to Combi Boiler In Zone 1! in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Wetroom Store - Network Wetroom Suppliers
Top Bottom
