Discuss Combing two lamps using 1 Plug in the Lighting Forum area at ElectriciansForums.net
Hi all,
My wife has purchased two vanity mirror lights from Ikea (Musik) which are both fitted with a 3a plug.
Each of the lights has an on/off toggle switch like most lamps. Is it possible to have both light comes on using the one switch/plug?
I had thought it would be straight forward enough but would like to get a seconds opinion. I thought this could be a possible solution?
Any help would be greatly appreciated!
Many thanks again,
Aidan
ideal solution is to replace the single socket with a twin. then plug each light separately
... with one these?
I think the issue was that the OP wanted both lights controlled by 1 switch only.
I cant see a problem if the joint is made correctly in an enclosure.
A few thoughts:
Looking at your diagram am I right in assuming that you want each light to be either side of a mirror, with one switch two turn the lights on?
Is this mirror in a bathroom or above a sink, because by the way the lights are wired my guess is they are not designed for bathroom use.
To save modifying the lights to achieve what you want, it would be better to do as telextrix has suggested and use a double socket to power both lights. If you want to switch them both on at the same time then you can use a single switch to turn on the power to double socket which could be unswitched. However this probably need some modification to your house wiring.
If you want to avoid any professional involvement from an electrician the simplest solution would be to plug the lights into a short two gang extension lead. This way one plug socket would switch on both lights. Leave the inline switches permanently on and use the plug socket switch as the 'master'.
Anything neater would probably involve getting a more expensive fitting and permanently wiring it in.
Thank you all for your contributions - very much appreciated.
The light is for a bedroom dressing room area. Sockets are not a constraint as we have ample sockets available, its more the convenience of being able to turn on both lights using the one toggle switch, instead of reaching over both sides of the dressing table to turn on individually. I was hoping to avoid using extension lead.
I guess i am seeking reassurance i am not doing anything that could jeopardise health and safety!
Again thank you for contributions!:clapping:
Reply to Combing two lamps using 1 Plug in the Lighting Forum area at ElectriciansForums.net
have a set of lights that i would like to use plug over battery. have a few plugs and old sets with cables could Frankenstein together if doable...
Can I use multiple GU10 led lamps with their own PIR sensors in the same room? I have a row of existing lamps 600mm apart in a straight line & I...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
