Discuss commercial ring rcd or mcb in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
matt sparks
hello all, just done a job to change a store into a small kitchenette. its in a commercial train depot, singles in pvc conduit buried in wall, has been tested by a nic tester and signed off. circuit protection is a 32a mcb, only chosen for the fact that the circuit is on the first floor, is commercial and all safe zones issues have been addressed also nobody of a general public type person is allowed to use or carry out any modifications to the lay out of the building, but the installation has been pulled by the maintainance sparks because of the mcb, quoting the 17th, any ideas were we stand?!! any answers full appreciated cheers.
think maybe if cables not buried over 50mm deep in wall or in earthed conduit it has to be on 30ma rcd. may be wrong tho but sure someone more experienced can give you the answer
ALL socket outlets need rcd protection complying with regulation 415 see reg 411.3.3 there are exceptions in 411.3.3 a & b but realistically you wont forfill them.
a) = under the supervision of skilled or instructed people.
but you cant guarantee that (cleaners etc) and how do you define skilled !
basically all sockets need rcd protection complying with regulation 415
remeber the reg youll be hearing loads about it:eek:
Reply to commercial ring rcd or mcb in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I’m going to call an electrician out on Monday, but curious if anyone has any ideas about this fault: I have a new kitchen fitted and two...
Hi Guys, Long time member and not a regular user here. I do pop in here when the odd unknown pop's up and unable to locate an electrical dilemma...
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
Been looking at a CU change in a small office and would appreciate comments on the following. Office is supplied from the mains intake in the...
6K
