Discuss Compatible downlights? in the UK Electrical Forum area at ElectriciansForums.net
Poozle
Hi,
I'm looking for some advice as I'm feeling a bit clueless! 3 of our 4 bathroom lights seem to be failing or on the way out. They flicker constantly and dim on and off. They have only been in about 4 years so we weren't expecting them to go so soon. I was thinking that we would just replace them so we took one down to see what it was and it's a Scolmore LED 4400ch7w. My question is, do I have to buy the same brand to replace the faulty lights, or are there other brands that are compatible (and cheaper!). I've had a look online but I don't really know where to start! Grateful for any advice!
Thanks!
what size is the hole/s in the ceiling? if 70mm or you can make them 70mm i recommend JCC V50 fittings.
You can put any light back in. However hole size can be different for different lights while you can't very easily make the hole smaller you can make it large with a bit of know how. More and more customers are rejecting the idea of a light that you have to replace completely rather than just change the bulb. And the LED lights touted as five years guarantee invariably don't meet such advertising puff I beleive it's called. So maybe get an IP44 light minimum, with an LED lamp that will replace your lights and then you just have to change the lamp, being much cheaper, in the future.
If you’re replacing the whole fitting then another brand is fine as long as they’re suitably IP rated. Look out for one with a similar or larger cut out to avoid the need to patch the ceiling
Thanks for the replies!
I can't reach the ceiling to measure the hole at the mo, but I think it is probably around 70mm - the chrome rim of light is 80mm. If I wanted to replace the lamp bit only in future, would I need to buy a replacement for the white bit that attaches to the cable and what is it called?
The house is an old house but it was rewired about 4 years ago and I believe these were put in as part of the re-wire. Unfortunately though, whilst we have the certification for the rewire I don't think we have any other receipts. There is insulation above the lights - will that invalidate any warranty?
What is the IP rating and what should I be looking for there. These ones say IP65 on the side.
Also, where would you suggest going for replacements? Will the sell them in B&Q, Screwfix? Or do I need to go to a specialist shop?
Thanks again for the replies!
Ring up Scholmore. They might be embarrassed into exchanging FOC.
Don't tell them they were covered in insulation though.
Those are just right IP rating wise. Anything of IPX4 and above.
Do not go to B&Q! Google your product, and buy them online.
Did you have to unplug the fitting if so no electrical work would need to be undertaken, just plug new fittings in. As suggested try Scholemore first see how you get on. Make sure the new lights are not covered in insulation.
You can fit anything to replace those downlights, but you will have to check the hole size and do some wiring to connect them.
If you don't want to do that then these will fit the hole and just plug in using the existing connectors fitted
Scolmore LED4600CH7D Inceptor Omni Fixed Dimmable Tri-Colour Switchable LED Fire Rated Downlight With Chrome Interchangeable Bezel & Flow Connector IP65 5.6W 240V, LED4600CH7D - http://www.discount-electrical.co.uk/product.php/404587420/scolmore-led4600ch7d-inceptor-omni-fixed-dimmable-tri-colour-switchable-led-fire-rated-downlight-with-chrome-interchangeable-bezel---flow-connector-ip65-5-6w-240v
FYI we had quite a few of the fittings that you've had fail, fail on us in a similar way. Interestingly it only seems to be the non dimmable type that have ever failed. If they were registered with Scolmore when installed, you will have a 10 year warranty.
Thanks for the replies. I will give Scolmore a call in the morning. I've had a look online, but it looks like they might have discontinued that model as the only place that model seems to be available is ebay at £36.99 each!!
Archy - were they lights like mine that you replaced? Is what you posted in the link not a bulb? (please forgive the ignorance!)
Thanks!
Reply to Compatible downlights? in the UK Electrical Forum area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
I have two downlights in my hall with MR16 bulbs. These are now leds, obviously in the past they were halogens. The fittings are really old and...
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
