Discuss Compliance certificate part P in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
OP
J
Johnf62
Out of interest...
Does the flat cable go into the plug (both red arrows) ? Might be optical illusion.
Is the fused spur with green arrow (with a tasty hole in top) now used for anything?
Hi, the pump cable goes in to the 13amp plug which is always on. Then another cable runs from the 13 amp into the white fused box above. The silver fused box is never on. It’s the old immersion heater So I think the white flat cable is not in use. Thanks
Reply to Compliance certificate part P in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all We've had some works done in our kitchen which has involved fitting a new cooker circuit, installing some downlights to replace ceiling...
Hi all, New to the forum! Quick background on me: I have a degree in electrical engineering and spent many years working with qualified...
4K
Hello, I understand that from the 15th of June testing and commissioning of vents and fans is now compulsory and that also since last year any...
I build a vanity mirror with 14 light bulb sockets that will have 5w led lights on it and need help with the electrical part. My light bulb...
Hi We would like to try and remove our fitted wardrobe and the first challenge I can see, being a bit clueless with this sort of thing, is the...
New Posts (Please Reply)
