Discuss Conduit Positioning in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
prs999
Hi, I don't have my full regs to hand and I can't find it in any of my onsite guides. I know cable buried in a wall can't be less than 150mm from the corner join of 2 walls but is there a minimum for cable in surface mounted pvc conduit? I have a ring main I need to get to the first floor and I can fit some conduit into an existing pipe boxing but only right in the corner of the room, is this ok? Cheers
wrong. can't be more than 150mm
The OP is wrong.You are allowed to bury a cable in a wall with no further mechanical protection within 150mm of a corner! Its a daft reg if you ask me but its allowed.
customer is unlikely to hang a picture that close to a corner. that's why it's been made a safe zone. otherwise, sometimes it would not be possible to run cables without steel containment.
Reply to Conduit Positioning in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
I've been told I need to upgrade the main earth bonding to 16mm. The consumer unit is on the wall adjacent to the externally mounted incoming...
4K
