T
Tasty
Hi all,
As ever, I prefer to check with others before proceeding with work I've not yet encountered, however I'm pretty sure I'm ok with this one.
The lady i'm helping is having a new gas top hob to replace her old one, however the company who are installing the oven/hob refused to wire the hob in as the existing wire goes behind the plaster to a FCU, and they don't want to touch electrics. Therefore they've asked for a socket or spur to be installed.
Now both hobs have 1.5mm 3 core flex, so I was thinking simply install a connection unit with a flex outlet plate where the current cable comes out of the wall, then wire the new hob into that outlet.
They also said I could just install a single socket, however I didn't think this was best as it will only be supplied by 1.5m cable and may be used incorrectly in the future.
The load will be for the ignition switch only, however I cant give the exact load as i've not seen the spec for the hob just yet.
Cheers if anyone can just confirm/advise me on this.
Stu
Stu
