Discuss Confused DIY'er needs advice on Chandelier fitting in the Lighting Forum area at ElectriciansForums.net
I have recently been given a chandelier that I would like in my bedroom, to replace the existing ceiling rose. However, I do not have the bracket that fits to the ceiling & I'm not sure what type/size bracket I need. Can anyone advise me please?
If anyone can send pic's of what I need, I'd be sooooo grateful
Thank you! :)
It looks like the tyoe that hangs on a hook and then you slide the metal cup up to cover it, we used to just use a cup hook screwed into something solid above the ceiling for that sort of fitting.
Obviously putting the electrical connections in a suitable enclosure too.
You'll need a plate bracket with a hook on it.
Great, thanks, presumably I can buy these on the internet? :)
[automerge]1589198782[/automerge]
Great, thanks for your help :thumbsup:
View attachment 58035View attachment 58036
Thank you! :)
Drill some screw holes in the plate shown, make your connections and screw the plate direct to the ceiling you might want to use some round head Brass screws as opposed to steel ones.
Which plate?
Are you suggesting drilling holes in the decorative cover to fix it to the ceiling?
In which case it won't stay up very long!
Reply to Confused DIY'er needs advice on Chandelier fitting in the Lighting Forum area at ElectriciansForums.net
Hi guys I need to put a chandlier in my siblings house. I've taken the old one off. As you can see in the pic. To put the bracket on do I just...
I have had these lights installed by a contractor whose work is normally very good. He has not connected the earth in each fitting as there is a...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
I am trying to replace a ceiling rose with a new chandelier. I had all the wiring carefully complete, turned the power back on and...trip! Tried a...
