Discuss Confusing light switch connections in the DIY Electrical Advice area at ElectriciansForums.net
I am replacing an old 2 gang switch with a new one (photo attached).
I know this is going to be a very simple question to answer, but;
There are no screw terminals that I can see and I am trying to work out how I connect wiring.
I have never come across a switch like this before. Anybody help?IMG_20190213_164411925.jpg
Welcome to the forum mate.
Not seen this before, so I'm guessing here.
Do you see the 3 grey levers at the top. Have you tried pushing them in and seeing if the holes facing front open up?
This is a Turkish claw terminal fitting. This type of design has a facia that plugs into the fitting
Looks like a 3 gang switch to me.
Also, it looks like the top connections are joined together.
I have never come across a switch like this before. Anybody help?View attachment 47813
Seemed to have reached an impasse Paul, where you should have employed a local electrician who knows what they are about to swap the switch over, sorry to be blunt but it happens time after time, people think it's a simple job, when in fact it takes a professional to sort it out in the end.
Reply to Confusing light switch connections in the DIY Electrical Advice area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
