Discuss Confussed...again 2330 or 2360 NVG? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
anjo
Hi thanks for helping if you can.
What are the differences between this two courses?
I am trying to decide a course to start in Sept and between this two I am unsure which one is best.
Also to add the course 2356. What is this course's standing in relation to 2330.
Anjo
The 2360 was the old course which has no been replaced by the 2330!
The 2356 is the NVQ3 which you will have to do in order to get "Qualified Electrician" status, it is a load of on the job assessments to prove to the assessor that you are competent, once passed you can call yourself a qualified electrician, NVQ3 you have to do whilst on the tools!
Hope this helps:)
Anjo
There is no more 2360 it has been replaced by the 2330. They are the same but with a different number!!
Ok once you have done your 2330, you apply to do your 2356 and receive a list of jobs that you need to do. Called assessments! When you take on one of the jobs that are on the list, you phone your assessor tell them where and when the work will be and he'll come out and watch you work. Once you have finished and passed all the assessments on the sheet, you will have gained your 2356 NVQ3
Mark:D
Reply to Confussed...again 2330 or 2360 NVG? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hello all Well, been putting it off, but I need to upgrade my 17th edition to the 18th. Not been a practising sparky for over 5 years, but I have...
Hi Guys, sorry if posting in the wrong section. I am due to start 2391-52 course soon, and there seems to be from what I have found out, a 3 phase...
Hi everyone, I am Tony. Just introducing myself. I am in a difficult position myself trying to decide at 38 with 1 kid about changing careers and...
I'm unsure if I should be an electrician or maybe another trade is better. I have basically completed my first year of a foundation in...
Hi I'm trying to get some closure on an on-going issue I have in regards to a final qualification certificate which is the C&G 2360 Part 2. I...
