Discuss Connecting 2-2-2-4 AL URD to interior subpanel in the UK Electrical Forum area at ElectriciansForums.net
OnMyOwn
Good afternoon, I was trying to figure out when running 2-2-2-4 AL URD direct bury in conduit to a building, how do you connect it to the inside sub panel? I think I heard that it can't enter a building and if so, then how do you get the wire inside? I am a DIYer and have a general understanding of electric installs. But still don't make it too techie please.
Thank you,
you willneed to hangfire tilla USmember comeson.over this side of the pond, most of us don't understand US terminology, :) :) :)
Thank you,
Not to Techie but what is 2-2-2-4AL URD? Aluminium Underground I get but can't figure the numbers genuine question
This is a pic of it.
Thank you,
@ownmyon it you are buying quadtriplex you don’t have to put it in pipe except when it comes out of th ground and then you just stub a peice of 2inch PVC pipe
Reply to Connecting 2-2-2-4 AL URD to interior subpanel in the UK Electrical Forum area at ElectriciansForums.net
Hi, I am burying wire from the outside meter panel to the new 100amp sub panel inside a garage. The run is 20' long. Is 2-2-2 Aluminum URD Cable...
I am connecting a manual transfer switch to a subpanel. In order to minimize drywall work, I am mounting the transfer switch to the surface of the...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
