Discuss connecting a busbar in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
P
philaxgt500
can someone help me answer this question?
describe the factors affecting the choice of wiring systems and cable? with reference to cables connected to bus bar operating at higher then normal recommended temperaturess for the cable.
cheers phil
The connection to the busbar should be lugged and the cable insulation should be removed by about 150mm before the Lug and replaced with heat resisting tape.
The last time I installed some the connection to the busbar was via tap off's - and bloody lots of them!
There maybe some new busbar system types these days.
cheers thats was the perfect answer, i asked my college teacher alan young and thats what he said, thanks for the reply:) got my home work done now:)
Reply to connecting a busbar in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello - I'm looking to help determine how many connections are allowed on my AC disconnect terminal lugs - Eaton DPU22R. I'm not seeing anything...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
I'm starting a new construction single-family residence, I know with the 2020 NEC they require an emergency disconnect on the exterior of the...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
