Discuss Connecting a wall light in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
bullethead
Hi all, I’d appreciate some advice on fitting a new wall light (not bought it yet but want to know options for fitting).....
The new light is designed to be wall mounted but has a plug for supply from a socket. However, I’d like to fit it in place of an existing wall unit which is on the lighting circuit and have the following questions:
- Can the new light be fitted by removing the plug and connecting directly to the existing supply or would it have to go via a fused unit? (Can’t think why as it would be on the 5A lighting circuit).
- If there is no need for the fused unit, is it acceptable to make the connection via a 5A terminal block (would still be accessible by lifting the light unit away from the wall)?
Many thanks.
It sounds like there was a wall light previously, so perfectly acceptable to connect as you describe with a terminal block and it will be hidden behind the fitting.
When I do the wiring for wall lights I use a metal architrave box with knockouts. Once flushed into the wall gives you plenty of room to house/conceal the connectors, and on many types of fittings the 3.5 mm fixing screws can be used to support the fitting itself !!!!!
fanta sounds good to use ko box if you see wall light first .u would be in trouble if fitting is narow and ur box is mounted horozontal;);)
The knockouts on "ARCHITRAVE" metal boxes are only located at the top and at the bottom of the box so vertical mounting is the normal way to install these small compact accessories !!!!!!!!!
Reply to Connecting a wall light in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Hi all, I am planning to install wall lights such as these ones (LAP Bronx Outdoor Up & Down Wall Light Black - Screwfix -...
Hi My Kitchen has never had a cooker hood installed. Where the new hood is going to be situated is some distance from any of the outlets in the...
  • Locked
Hi I also posted this on the DIY Electrical Advice - Electrical Appliances Forum My Kitchen has never had a cooker hood installed. Where the new...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
